PostgreSQL or Valentina? How do I know?
Mari-AnneMari-Anne Posts: 363
I have installed the PostgreSQL CMS (Win-64) as well as the PostgreSQL CMS From Valentina CMS Conversion via the latest DIM, but how do I know that Daz Studio 4.7 Pro is really using the PostgreSQL DB instead of the Valentina DB?
When I check Edit > Preferences > CMS Settings tab, the Cluster directory shows:
C:/Users//AppData/Roaming/DAZ 3D/cms
which doesn't really tell me which database is being used. I am using Windows 8 64-bit version.
  • Richard HaseltineRichard Haseltine Posts: 112,021
    If you have the CMS Settings tab in Preferences then you are using PostgreSQL.
  • namffuaknamffuak Posts: 4,538
    Two ways - with Studio running, open the windows task manager and look at processes; you should see multiple postgres processes. Also, go through help -> troubleshooting -> view log file -- you should see this line:
    Connected to CMS: PostgreSQL 9.3.4, compiled by Visual C++ build 1600, 32-bit
    except that yours should indicate 64-bit.
  • Mari-AnneMari-Anne Posts: 363
    Thank you, Richard and namffuak!! Perfectly answered my question.
