How do I add WASD - IK - hotkeys to Undo Camera Transform history?
Sometimes I'll accidentally move a camera by hitting W,A,S,D,I,K keys.  Unfortunately, these camera transforms don't get added to the undo history, so I can't undo it, and I lose my original camera angle.
  • SpaciousSpacious Posts: 481
    Sounds like you may be using the default perspective view and not an actual camera.  Default perspective view is lacking a bunch of the settings that a camera has, also it does not store movements into any history.  Try creating a camera and it will have settings for focal length, focal distance, depth of field, and also it will log its location changes into your undo history.   Hopefully this helps.
  • vozolgantvozolgant Posts: 207
    Unfortunately, using those hotkeys, even with the camera selected in the top right; not using perspective at all, doesn't record undo transform changes.   Basically, using hotkeys to move the camera is permanent, and cannot be undone.
  • Richard HaseltineRichard Haseltine Posts: 111,371
    I keep the WASD navigation off for just this reason, as far as I know it cannot be added to the undo stack. You coudl select the camera and then use Edit>Object>Memorise>Memorise Selected Node(s) so that you coudl then restore the camera settings if need be (but of course you would then have to rememorise after any intentional change).
    That's a good idea, thanks.
    I also disabled all hotkeys that move the camera.
