G8 UV Swap Issue with character
Ok, I am having a weird issue I had not run into before and hopefully can figure it out. I am trying to use a G8M UV on a female G8F. I have done this many, many times without issue. However today I followed the usual way of doing it:
https://www.daz3d.com/genesis-8-uv-swap-male-and-female-base - (Uv Swap) I use this.
to put
https://www.daz3d.com/overkill-hd-for-genesis-8-males - (Overkill Material) Onto the female.
And it messes up the texture all around her legs and shoulders.
However, while Overkill's material works perfectly fine on a G8M, event though my female can have any other male metaerial I am choosing, for some reason Overkill messes it up. Any ideas what is with this particular male material and how I work around it?
Ok, I checked the UV's and now I see what it is! The Overkill uses something called zombie overdrive. It's on the drop down list on the male, but not the female. Looks like I won't be able to do what I had planned since UV swap does not let me choose other UV's for G8M, I suppose.
