32 or 64 bit
aqua1955aqua1955 Posts: 20
I downloaded the file but looked at it and it is a 32 bit version.
Is there also a 64 bit version? And if where can I download it?
    edited November 2014
    I assume that you are talking about the DS file?
    If you go to your product library you should find there is both 32 and 64 bit files. At the bottom of the list
    https://www.daz3d.com/downloader/customer/files#prod_13176
    Post edited by Chohole on
  • Richard HaseltineRichard Haseltine Posts: 111,491
    If, on the other hand, you mean the Install manager then it doesn't have a 64 bit version as it doesn't handle large enough chunks of data. It can however install the 64 bit versions of applications that have a 64 bit version without problem.
