Object LIbrary-Tutorials
mermaid010mermaid010 Posts: 6,321
edited December 1969 in Bryce Discussion
A quick question.
In the Objects library under Installed there is a category Tutorials. Create-Installed-Tutorials. Do these objects refer to tutorials? Each of the 3 objects has “Use for "Arranging Objects in the Scene". How does one use them to arrange objects? :roll:
Thanks
  • Tim82Tim82 Posts: 859
    are you referring to the beach props ?
  • mermaid010mermaid010 Posts: 6,321
    Yes Tim the beach props, do you know if there are tutorials that go with it?
  • Dave SavageDave Savage Posts: 2,435
    I think they are a relic of a previous version of Bryce... I'll have a scout round and see if I can find out. :)
  • HoroHoro Posts: 11,779
    edited November 2014
    There was once a tutorial. Bryce 4 doc pp 47, Bryce 5 (German) doc pp 35. I couldn't find any tutorial for Bryce 5.5, 6.0, 6.1, 6.3, 7.0 and 7.1 that refer to these very old objects. They are already there in Bryce 4.0.
    640 x 478 - 45K
    Post edited by Horo on
    Thanks Tim, Dave and Horo for your replies.
    I don't think I can get hold of the an old manual, it would have been interesting to see "How does one use them to arrange objects?" ;-)
    I think it refers to using them for the tutorial about arranging objects in a scene. :)
    Yes that's what I thought too Dave. I still have problems placing objects in a scene and thought maybe I would get some ideas. :-) I suppose trials and errors are the key to success.
  • TrishTrish Posts: 2,625
    mermaid: I don't know if this will help or not but what I do is look at the scene from above...that helps me arrange objects...also I lock what view I want to make it easier...but you probably know that already....Trish
    208 x 264 - 19K
    Post edited by Trish on
    @mermaid010 - good advice from Trish, I think. I use the perspective camera, not the director's one, and set all rotation angles to 0. Looking from above, ahead (or north) is up, right right (east), down towards the viewer (south) and left left (west). I also decide what size the scene has e.g. 1 m/3 ft for a table top, or 3 km/2 mi for a landscape, then I determine how much a BU (Bryce Unit) is. This makes it relatively easy to scale objects and know how far away from each other they should be.
    Thanks Trish and Horo. Since I started doing David's tutorials I mainly use the perspective camera. Another thing I learnt from David is using the different views-camera, top and right. I'm trying an interior scene and just can't get the objects where I want them.
    Thanks once again.
  • GussNemoGussNemo Posts: 1,855
    To see what things look like so far, I use the camera view. When I'm trying to get things placed in a particular location I'll switch from top to right to director views, whichever view helps to get things positioned. Then it's back to camera view to see if things are like I'm after. And if I want to get close to a particular location then I'll use director view so I can pan around to get a look from several different angles. Using the keypad really helps to switch views quickly.
    Thanks Guss for your suggestions. :-)
    This small item often gets unnoticed. The Plop-render tool has the zoom to selection option. Just make sure you've saved the camera position in a dot before you zoom.
    354 x 345 - 45K
  • FishtalesFishtales Posts: 6,245
    I tend to setup in camera view and then use the top or right view to move the objects. I use the + and - zoom buttons at the side to zoom in and out centred on the selected object.
    Thanks Horo and Sandy, I appreciate all the suggestions. :-)
    @mermaid: You're welcome. It was the last two cents I had for the day.
