looging for a basic terrain generator
golem841golem841 Posts: 231
I tried
- Terragen, but the free version doesn't allow any kind of export
- TerreScuptor 2 and I have trouble applying a shader to the obj file exported
- Quad Spinner Gaea is promising but lack a simple export option.
- Sadly, I plan to cancel my annual subscription to Eon/Vue since I can't reasonably afford the yearly fee necessary to continue using the program ... I will not elaborate on this particular point, but it's to the least very unpleasant ...
I just need a simple program to use with Howie Farkes products
Could anybody point me to such a thing ?
Thanks
  • FishtalesFishtales Posts: 6,244
    Have you tried this?
    https://terrain.party/
  • WendyLuvsCatzWendyLuvsCatz Posts: 41,853
    Bryce
    Has a bridge to send the terrains to DAZ studio but you may need to use different textures
  • mdingmding Posts: 1,764
    Does it make sense to use bryce if i only need the uv mapped mesh to texture it in daz for iray?
  • thd777thd777 Posts: 947
    edited May 2021
    @golem841 I use Quadspinner's Gaea. It does have many export options, so I am not sure what you are looking for when you say it does not have a simple export? I usually export a .obj file from Gaea and texture in DAZ studio with the multi layer terrain shader. I use masks exported from Gaea to distribute the layers.
    ciao
    TD
    Edit to add an example. Here is Gaea terrain in DAZ Studio. Exported as 2K*2k .obj and textured in DS.
    2500 x 1141 - 3M
    Post edited by thd777 on
  • golem841golem841 Posts: 231
    I should probably spend more time learning to use Gaea.
    I bought it because of the excellent work Quadspinner made for Vue.
    Unfortunately I do not have enough time for all my hobbies...
