Stopped working script in DS 4.7 - Props Export - PP2 exporter 20d
Andrey PestryakovAndrey Pestryakov Posts: 172
edited November 2014 in Daz Studio Discussion
There was a good script for DAZ Studio. Worked fine in DS 4.6 - script created PP2 and optimized geometry of reducing the size for OBG.
In DS 4.7 geometry disappears ... Can you fix it?
Post edited by Andrey Pestryakov on
  • Andrey PestryakovAndrey Pestryakov Posts: 172
    Is any alternative to this script to generate PP2 props from DS 4.7?
  • Richard HaseltineRichard Haseltine Posts: 111,348
    Merged duplicate threads.
    Is this a link to the original file? You can't repost that without permission, and no one can edit the script and give you the modified version without permission. Someone could tell you how to edit it yourself, however.
    I deleted the file.
    PP2 Export.dsa by JWAS84 and DUKE533 carries a zero-restriction copyright. Anybody's free to update/distribute.
    Portion of the file:
    ** PP2 exporter 2.0d
    ** Description: Export Prop with limited Mat support.
    ** Authors: JWAS84, DUKE533
    ** 24-02-09 ver 1a (JWAS84)
    ** (c) Copyright NONE. Use for whatever you like.
    ** ExportObj Was written by Rob Whisenant.
    ** renderIcon Was written by Guandalug
    I can't code for Daz to save my soul, but if someone's willing to update it to work with 4.7 I can pass it along.
    Post edited by Lissa_xyz on
  • BejaymacBejaymac Posts: 2,002
    The last version of it was actually posted on the old forums, that way people could just copy & paste it into an empty DSA, sadly that forum is long gone (as is the archive) but I do have the code from that post and can post it here if anyone wants it.
    I had to put DAZ Studio 4.5, to use this script.
    No, it creates a .pp2 prop file.
    I managed to find a version of it posted by MFM on these current forums, dated September 2013.
    http://www.daz3d.com/forums/discussion/27536/P1035/#423087
    Looks like his last fix was for AoA's SSS.
    The script itself loads and exports, and the pp2 loads into the scene hierarchy, but there's no visual object.
    I used it just to export a standard cube prim.
    What saved into the OBJ:
    # Exported from DAZ Studio 4.7
    # cube
    v -1.98722e+18 7.28961e+19 1.98959e-23
    v 1.98722e+18 7.28961e+19 1.98959e-23
    v -1.98722e+18 -7.28961e+19 1.98959e-23
    v 1.98722e+18 -7.28961e+19 1.98959e-23
    v 1.98722e+18 7.28961e+19 -1.98959e-23
    v -1.98722e+18 7.28961e+19 -1.98959e-23
    v 1.98722e+18 -7.28961e+19 -1.98959e-23
    v -1.98722e+18 -7.28961e+19 -1.98959e-23
    vt 0 0
    vt 0.33 0
    vt 0 0.5
    vt 0.33 0.5
    vt 0.66 0
    vt 0.99 0
    vt 0.66 0.5
    vt 0.99 0.5
    vt 0.66 0.5
    vt 0.99 0.5
    vt 0.99 1
    vt 0.66 1
    vt 0.33 1
    vt 0 1
    vt 0.33 0.5
    vt 0.66 0.5
    vt 0.66 1
    vt 0.33 1
    g Default
    usemtl cube
    f 1/1 2/2 4/4 3/3
    f 5/5 6/6 8/8 7/7
    f 6/9 1/10 3/11 8/12
    f 2/2 5/5 7/7 4/4
    f 3/3 4/4 7/13 8/14
    f 6/15 5/16 2/17 1/18
    The PP2:
    version
    number 4.01
    // PP2 exporter 2e
    prop cube
    storageOffset 0 0.3487 0
    objFileGeom 0 0 ":Runtime:Geometries:!PP2 Export Test:cube.obj"
    prop cube
    name cube
    on
    bend 1
    dynamicsLock 1
    hidden 0
    addToMenu 1
    castsShadow 1
    includeInDepthCue 1
    useZBuffer 1
    parent UNIVERSE
    creaseAngle 80
    channels
    xOffsetA OriginX
    name OriginX
    initValue 0
    hidden 1
    forceLimits 0
    min -100000
    max 100000
    trackingScale 0.004
    keys
    static 1
    k 0 0
    interpStyleLocked 0
    staticValue 0
    yOffsetA OriginY
    name OriginY
    initValue 0.12499999812268835
    hidden 1
    forceLimits 0
    min -100000
    max 100000
    trackingScale 0.004
    keys
    static 1
    k 0 0
    interpStyleLocked 0
    staticValue 0.12499999812268835
    zOffsetA OriginZ
    name OriginZ
    initValue 0
    hidden 1
    forceLimits 0
    min -100000
    max 100000
    trackingScale 0.004
    keys
    static 1
    k 0 0
    interpStyleLocked 0
    staticValue 0
    translateX xTran
    name X Translate
    initValue 0
    hidden 0
    forceLimits 0
    min -100000
    max 100000
    trackingScale 0.001
    keys
    static 0
    k 0 0
    interpStyleLocked 0
    translateY yTran
    name Y Translate
    initValue 0
    hidden 0
    forceLimits 0
    min -100000
    max 100000
    trackingScale 0.001
    keys
    static 0
    k 0 0
    interpStyleLocked 0
    translateZ zTran
    name Z Translate
    initValue 0
    hidden 0
    forceLimits 0
    min -100000
    max 100000
    trackingScale 0.001
    keys
    static 0
    k 0 0
    interpStyleLocked 0
    rotateX xRotate
    name X Rotate
    initValue 0
    hidden 0
    forceLimits 0
    min -100000
    max 100000
    trackingScale 1
    keys
    static 0
    k 0 0
    interpStyleLocked 0
    rotateY yRotate
    name Y Rotate
    initValue 0
    hidden 0
    forceLimits 0
    min -100000
    max 100000
    trackingScale 1
    keys
    static 0
    k 0 0
    interpStyleLocked 0
    rotateZ zRotate
    name Z Rotate
    initValue 0
    hidden 0
    forceLimits 0
    min -100000
    max 100000
    trackingScale 1
    keys
    static 0
    k 0 0
    interpStyleLocked 0
    scale Scale
    name Scale
    initValue 0
    hidden 0
    forceLimits 0
    min -100000
    max 100000
    trackingScale 0.004
    keys
    static 0
    k 0 1
    interpStyleLocked 0
    scaleX xScale
    name X Scale
    initValue 0
    hidden 0
    forceLimits 0
    min -100000
    max 100000
    trackingScale 0.004
    keys
    static 0
    k 0 1
    interpStyleLocked 0
    scaleY yScale
    name Y Scale
    initValue 0
    hidden 0
    forceLimits 0
    min -100000
    max 100000
    trackingScale 0.004
    keys
    static 0
    k 0 1
    interpStyleLocked 0
    scaleZ zScale
    name Z Scale
    initValue 0
    hidden 0
    forceLimits 0
    min -100000
    max 100000
    trackingScale 0.004
    keys
    static 0
    k 0 1
    interpStyleLocked 0
    xOffsetB xOffB
    name xOffB
    initValue 0
    hidden 1
    forceLimits 0
    min -100000
    max 100000
    trackingScale 0.004
    keys
    static 1
    k 0 0
    interpStyleLocked 0
    staticValue 0
    yOffsetB yOffB
    name yOffB
    initValue -0.12499999812268835
    hidden 1
    forceLimits 0
    min -100000
    max 100000
    trackingScale 0.004
    keys
    static 1
    k 0 0
    interpStyleLocked 0
    staticValue -0.12499999812268835
    zOffsetB zOffB
    name zOffB
    initValue 0
    hidden 1
    forceLimits 0
    min -100000
    max 100000
    trackingScale 0.004
    keys
    static 1
    k 0 0
    interpStyleLocked 0
    staticValue 0
    origin 0 0.12499999812268835 0
    endPoint 0 0.2499999962453767 0
    orientation 0 0 0
    displayOrigin 0
    displayMode USEPARENT
    customMaterial 1
    material cube
    KdColor 1 1 1 1
    KaColor 0 0 0 1
    KsColor 0.6 0.6 0.6 1
    TextureColor 1 1 1 1
    NsExponent 0
    tMin 0
    tMax 0
    tExpo 1
    bumpStrength 0
    ksIgnoreTexture 0
    reflectThruLights 1
    reflectThruKd 0
    textureMap NO_MAP
    bumpMap NO_MAP
    reflectionMap NO_MAP
    transparencyMap NO_MAP
    ReflectionColor 1 1 1 1
    reflectionStrength 0
    material Preview
    KdColor 0.654622 0.497543 0.861782 1
    KaColor 0 0 0 1
    KsColor 0.187072 0.0360363 0.131175 1
    NsExponent 5.0
    tMin 0
    tMax 0
    tExpo 0.6
    bumpStrength 1
    ksIgnoreTexture 0
    reflectThruLights 1
    reflectThruKd 0
    textureMap NO_MAP
    bumpMap NO_MAP
    reflectionStrength 1
    locked 0
    backfaceCull 0
    visibleInReflections 1
    visibleInRender 1
    displacementBounds 0
    shadingRate 0.2
    smoothPolys 1
    doc
    addActor cube
  • NagraNagra Posts: 99
    Cool information in here. Thanks for posting the link to the script !
    Glad i made a backup of the latest 4.6 before updating to 4.7 ...
    Good find for the code! thanks.
  • mCasualmCasual Posts: 4,607
    i located the problematic section of the code that makes it fail in DS4.8
    around line 741 there's a line of code that reads
    oNode.setWSScale( DzMatrix3() )
    if we replace that line with
    //changes by mCasualJacques July 20 2015 ** begin **
    // oNode.setWSScale( DzMatrix3() );
    oNode.getScaleControl().setValue(1);
    oNode.getXScaleControl().setValue(1);
    oNode.getYScaleControl().setValue(1);
    oNode.getZScaleControl().setValue(1);
    //changes by mCasualJacques July 20 2015 ** end **
    it appears to work !!!
    so i wont need to stay in DS3 when building my props
    i'll double check that the code i got has the permissive copyright clause ...
    yes !
    // DAZ Studio version 3.0 filetype DAZ Script
    ** PP2 exporter 2.0b
    yes !!!
    so i'll post the DS4.5+ compatible version on my site and on a Forum Thread
    edited July 2015
    well actually i better build or obtain a correct DzMatrix3
    in case the parent note has non-unity scaling
    so i wont use the getXScaleControl().setValue(1) way
    it will be
    oNode.setWSScale( DzMatrix3(1,0,0,0,1,0,0,0,1,0,0,0) ); if we're in DS4.5
    and if we're in DS 3 it will be the old code or this one if it's compatible
    and i'll fix the disappearing buttons issue
    and there's an error in the props that make their default scale 0 instead of 1,
    so when you "zero" most of my props, they disappear because they get scaled to 0% !
    so around line 393
    /* mCasualJacques change - important that the default zero scale is 1 not 0 */
    //writeLine("initValue 0");
    writeLine(String("initValue %1").arg( nVal ));
    Post edited by mCasual on
