Hair doesnt move with figure when posing
dannybrightonlinedannybrightonline Posts: 46
Hi,
I was attempting to pose my genesis 2 figure and the hair doesn't move with her when I pose her. I know it is a simple
fix but dont know how so I thought Id post.
Any ideas?
thank you
danny
    What's the hair you're using? Most hair is conforming and will automatically fit to the figure when added as long as Genesis is selected. If you're using an older Victoria 4 or similar 'prop' hair, you'll need to parent it to the head after adding it using the 'Parent in place' option.
    Some hair is conforming, other hair needs to be parented to the figure's head.
    Select the hair in the viewport (or Scene pane) right click, and select 'Fit To'. If the hair is a prop you may need to use 'Change Parent' and select the head from the drop down list.
    One more wrinkle: if the hair is a prop, and when you parent it, it doesn't look like it fits properly, check for morphs. Many prop hairs have morphs to fit to different base figures.
