Day 2 of "Thankful for Freebies" seems not to work
I am trying to check out with the following:
Sighni Outfit for Genesis 2 Female(s)
Odd Budle
K-Nicky Hair for Genesis
LNA Tokyo for Genesis 2 Female(s)
The hair does not drop to zero, that's for sure. I tried to swap LNA for the poses, but it did not work either.
I would also know to learn if we still retain the return policy during the sale. I don't see a warning that we don't, but it is better to be safe than sorry. I have a rule of thumb I don't buy unless I can return the item just in case. Lastly, can I add, say, LNA with K-Nicky AND Bush Rosa Mahalis with Sushi Time Two? Those are items from two different days. I'm asking, because this combination doesn't work for me either.
Worked for me, both with just the Tokyo outfit and K-Nicky hair and with the other 2 items you mention added. Hair showed as free with both combinations when I went to checkout.
Hmm... Then I am logging out again and logging in afterwards. Though my cache is clear...
EDIT:
Nah, it doesn't work. I have a suspicion that it is FOUR-MORE what butchers it up. Without the coupon, it works, but with it, it doesn't. Geez, I wanted to use it, it will expire soon if I don't (do you know when, by the way?). SHARECG doesn't affect it. And could you tell me please if we can return the products using this promotion should we decide they're not what we hoped for? I'm considering both LNA and Shuttlestar Poses, but I am unsure.
