Can d-force simulate a floating swimsuit?
Just one of those embarrassing moments you dive in a swimming pool, your swimsuit comes loose, and oops...embarrassing wardrobe malfunction!  I'm using the Utopia balcony's swimming pool, I'm not sure if what I have in mind is possible, the swimsuit needs to look like it's floating
  • SeraSera Posts: 1,675
    There is a gravity setting in the simulation tab. Try setting it to a negative value. That should make things float instead of fall. I would start with -0.3 or something, then adjust up or down as needed.
  • comixfanacomixfana Posts: 278
    certaintree38 said:
    There is a gravity setting in the simulation tab. Try setting it to a negative value. That should make things float instead of fall. I would start -0.3 or something, then adjust up or down as nIeeded.
    I'll give it a try! thanks!
  • pwiecekpwiecek Posts: 1,598
    Off Topic, but Nirvy has a wide variety of clothing with "discarded" morphs. Perhaps onr of those would give the effect you want.
  • RGcincyRGcincy Posts: 2,864
    edited April 2021
    I gave it a try using normal gravity (1.0) and letting swim trunks drop to the water surface in a 30-frame animated simulation. Then I adjusted the swim trunks Y-translate so they were half-submerged.
    615 x 492 - 218K
    Post edited by RGcincy on
    That looks really good!
  • RuphussRuphuss Posts: 2,631
    whos that Nirvy ?
  • Mark_e593e0a5Mark_e593e0a5 Posts: 1,603
    Ruphuss said:
    whos that Nirvy ?
    Exclusively on the other store. The nature and presentation of her clothing does not fit well in the Daz no-nudity policy.
  • There are a couple of vendors who provide extra morphs for a piece of clothing (i.e. on a hanger, on the floor etc.). Nirvy at Rendo is one of them, JaMaRe and Sparkman are others. Can recommend all of them - and their clothing ;-)
    Considering clothing these three are - with Kaleya, Lully and Silver_Snake - are my "go to PAs", just because of the non-standard options they deliver with their products, which are mostly utterly lacking in most clothing products here in the DAZ shop.
