cannot export animation properly
My name is Bilal Although I am not exactly a first time user for 3d softwares. I have only just started using daz 3d. My issue is that I have pz2 format facial animation which I want to use on a daz character The animation file imports fine and is also played correctly in daz but when exported the resulting file has no animation I have tried baking to transforms and I have tried to export as fbx as well as daz to blender bridge result is more or less the same In best case scenario the model is exported with rig but there is no animation data
Update: I have found a work around to the problem but would still appreciate if someone can help me with this since it will cut down my work flow considerably
You could try diffeomorphic. It is able to import animations and isoften better than the original daz-blender bridge.
http://diffeomorphic.blogspot.com/p/daz-importer-version-15.html
Thank you @ps2000 I just tried the diffeomorphic its much better but still facial animation is lackluster character doesnt open the mouth
