DS 4.7 - Cartoon shaders "missing"?
thrain9thrain9 Posts: 108
I am liking the new render system, but I have not been able to find where to switch from the default render shader to the cartoon shader..., in 4.6 you just clicked the drop down box in shader settings and could switch back and forth, but the 4.7 shader settings has no such item (that I have found yet)
I played around with the shader bricks in the shader creator system, but really have no idea what I am doing. ie. I made a total mess of things. I am back to default now, but still really want to create cartoon renders.
Also, is there a quality setting anymore? or is that handled by the spot render tool now.
Thank you in advance for your help.
    The built-in render option was never that good so I wouldn't be surprised if they did decided to drop it.
  • witcomicswitcomics Posts: 1
    edited February 2015
    Hi, the cartoon render style is under Render tab > Options > Show Hidden Properties
    Then in General > Style > Cartoon
    To work, you need to choose Engine: Intermediate OpenGL ;)
    Regards!
    773 x 398 - 120K
    Post edited by witcomics on
  • Richard HaseltineRichard Haseltine Posts: 112,021
    Cartoon Mode is a 3delight option, too - but it affects only surfaces using the default DAZ Shader (which is, a far as I know, the only one with OpenGL sahder code too - that's why it will work on all surfaces if you switch to the intermediate OpenGL render engine).
