Nedding Help with Transfer Utility(Selfmade Cloth)
Hey Daz 3D Forum PPL'S
I need help with that,
i Maked a Cloth with "Marvelous Designer", When i Import it in Daz 3D everything is Fine the Size, the Colour everything., but when i make "Transfer Utility" From Genesis to my Cloth it Looks Really Strange and the Size changes ,anyone can Help me Pls?
Hope Someone Can Help me
Thanks
740 x 696 - 97K
733 x 756 - 97K
  • Richard HaseltineRichard Haseltine Posts: 111,890
    Clothes for Genesis 1 should ideally be made around the base shape. Since it appears you didn't, and would probably have found it hard to get good results if you had, in the Transfer Utility you need to set the Source Shape to the morph you are using (or to Current if you are using multiple morphs), then click the more options button and check Reverse Source Shape from Target.
  • edited December 1969
    Omg Well Youre a GOD , Thanks for the answer, its everything Fine now C:!
    You're welcome, and I look forward to the delivery of sacrificial maidens.
    HEHE !:D
    For an question Works the Transfer Utility with all Morphs and Charackters on the Daz 3D Store?
    It should, yes - but check the figure to see if there is any scaling applied, and if there is reset it to 100%. Josie is thetrickiest as there's also some translation on the hip which needs to be set to 0 before exporting to use as a model in Marvellous Designer
