Render for the Realistic but "hey it is 3D" feel.
Hello,
I want to make some Renders with a mix of realistic 3D but schowing the 3D elements on an other part.
Something like this but nur by mixing some screenshots of the workspace.
I want to create a realy nice Iray render in high resolution. And then doan other render of the same size and perpective with only the seeing the lines.
With come gradient mix of the poligon outlines and the final Render. It is no problem to mix that in photoshop. But to creat the high definition, not Iray render part ...
I could not found an option for the render to use the preview cam setting to render.
Thanks!
  • JasonWNalleyJasonWNalley Posts: 122
    edited April 2021
    I'm having trouble understanding what you're asking for, sorry...  Are you looking for how to render the image with Iray?  Or how to render the image showing the wireframe?  If it's the former, there are a bunch of youtube videos, if it's the latter, then this may help: https://www.daz3d.com/wireframe-render-for-iray However, that's a script that just does something you could do on your own (though doing it takes quite a while from the way the description reads).
    Hope this helps
    Post edited by JasonWNalley on
  • marblemarble Posts: 7,500
    Your link has an extra space at the end so doesn't work. I think that product might help though if I understand the requirement correctly. I've seen images like that before - a kind of blend from wireframe to realistic which kind of says "you thought she was real but look, she's just CGI". As to how to do it, sorry - no idea but I hope to see the finished results here.
  • Thanks @marble I fixed the link
    Hope this helps
    Thank you! This is actually more than I was looking for.
    To choose the object to add the wireframe, might give much more room for renders.
  • WendyLuvsCatzWendyLuvsCatz Posts: 41,518
    he wants to do what you can do in iClone and probably other software engines, choose the drawstyle for individual items, ie Photorealistic for some, wireframe for others.
    and no, iray doesn't even have a no shadow option so its all or nothing
