Body morph is doin' a flip
I have finally been successfuly at getting a morph to load, but when I do, it is flipping along the up-and-down axis. I made the morph in Blender, and I am wondering if it is a difference between the axis, but I have fiddled with it to no effect. And when I use a pose, things get wacky and the limbs go all swirly. I am sure someone has come across this before? Thank you!
  • Richard HaseltineRichard Haseltine Posts: 111,816
    Please put the Viewport in Smooth Shaded Drawstype if you need to show a nude figure.
    The flip is lamost certainly down to mis-matched axes - the bst way to avoid this is to make sure that the preset in the OBJ export dialogue is the same as the preset in Morph Loader, and to not allow Blender to make any adjustments on import and export.
    That may well fix the distortion when posing; if not you will need to use Edit>Figure>Rigging>Adjust Rigging to Shape, then use ERC Freeze to link the morph to the adjustments (right-click in the parametrs pane and put it in Edit mode, if it isn't, then right-click on the slider for your morph and select ERC Freeze - check the list of Sub Components to make sure it isn't including anything it shouldn't).
  • Here are my settings, I have tried to make them match up, and it either is doing exactly the same thing, or is giving an error that the mesh is not matching.
    543 x 475 - 73K
    273 x 703 - 50K
  • Thank you - I had to try another export and keep an eye on those settings, and it seemed to work better. Have to pay closer attention next time to that I guess.
