?? How do I spawn a deformed prop from a finished DForce drape ??
DiomedeDiomede Posts: 15,466
How do I spawn a deformed prop from a finished DForce drape?
Once again, I am missing something really simple.  Or, I am confusing the capabilities of two different draping programs.  I just can't find the convert 'button' where I expect to find it.  Not in the DForce menu and not in the geometry menu.  I have draped a DForce enabled clothing item for G8M on a 'hanger' (some primitives).  I want to convert the draped item to a prop so I can safely add it to future scenes with zero fuss..  I can't remember how and I can't find it.
1234 x 839 - 130K
1549 x 923 - 202K
  • Richard HaseltineRichard Haseltine Posts: 111,803
    Hide everything but the item, make sure the resolution is set to Base, File>Export as OBJ, clear the simulation, then Edit>Object>Morph Loader Pro, select the OBJ (and make sure the preset is the same as used for export). There isn't a built-in spawn option, though you could certainly make a feature request for one (via a Techncial Support ticket).
  • DiomedeDiomede Posts: 15,466
    Thank you for your prompt reply.
    Looks like I am confusing DForce with another draping program which had a 'convert to static prop' option.  Will use the brute force OBJ/morph option going forward.  sad
    Much appreciated
