Question about the new daz format and rendering (solved)
halfmast88
I cant seem to figure out how to change the pixel dimensions like I could before the update to 4.7. It seems to just pick its own Pixel dimensions in the render tab. I have tried clicking on the "unlock" button but then there is no auto follow anymore to adjust the other pixel dimension. Is there a way to change some setting so it behaved more like before? -Thanks
Post edited by halfmast88 on
It is still much the same as it was, although it does look a lot different.
If you have Active Viewport selected, then that is the size you will get, that cannot be changed, it is the size of your current viewport. To change the final size of a render, go to render Settings > Editor > Dimension Preset (Global), and in that dropdown, select something other than Active Viewport.
You can use any one of the options on the dropdown, such as as Custom, Display Wide etc. etc.
Thanks!
