Wireframe render
cesar331cesar331 Posts: 0
Good afternoon,
There is a way to make a wireframe render?
Thanks.
    Not to render, no.
    But you can set the Viewport to Wire Texture Shaded or Wire Shaded, and use the Print Screen button. That is the only way that I know of.
    If you render using Hardware render it will render as you see it in the viewport.
  • cesar331cesar331 Posts: 0
    Not to render, no.
    Thanks, but I need the image in a high resolution.
    Thanks. I used the "Hardware Assisted Render" and put the figure in wireframe in the viewport, but the render still was textured.
    cesar331 said:
    Not to render, no.
    What's the exact version number? 4.6.3.12 or higher should render using the current draw style.
  • almahiedraalmahiedra Posts: 1,374
    I don't see hardware option in DS 4.7. There is a "Basic openGL" option which does the wireframe perfectly. Use diffuse color to change wireframe color.
    Yes, it's called Basic OpenGL in 4.7.
    Thanks.
    The version I'm using, is 4.6.3.52 Pro.
    But, the options you are speaking of, are not present under "Render Engine".
    There is no render Engine button that I know of?
    You will find the setting in Render > Render Settings as shown below. Move the slider to the bottom as shown below.
    Does that help?
    266 x 556 - 55K
    Yes, "Render Style", that was what I meant.
    I downloaded the 4.7 version, so it worked now.
    Thanks.
