DAZ 4.7 Upgrade problems
ZeuxidamusZeuxidamus Posts: 87
I updated my Daz4.6 to 4.7 yesterday, now anytime I try an load a g3f figure I get a "duplicate formula found in file" everytime, every g2f figure, everything else seems to load fine (props and g2m figures tested). I have only been using this program for about 6 months so be gentle.
  • Richard HaseltineRichard Haseltine Posts: 111,398
    Usually that means a morph is in need of editing - there are several packs that will do that, freebies or from other stores. However, it should have done it in 4.6 too. If you go to Help>Troubleshooting>View Log and search the text file for "Duplicate" you should be able to find the full message, which will tell you what is causing the issue.
  • ZeuxidamusZeuxidamus Posts: 87
    Well it was growing up looks like, didn't get the message after uninstalling that app. Now how do I get it reinstalled where it will work
    AH, there was a recent update which didn't include exactly the same fiels as the original, so if the original wasn't unisntalled that could happen. make sure that the files from the older Growing Up are fully removed - \Data\DAZ 3D\Genesis 2\Female\Morphs\Zev0\Growing Up as I recall - then reinstall the current version.
    Thank you very much sir.
