Face Morph Help
Trying to make a "parent" morph that I can use on a child to give it similar face features.
I have tried using:
http://docs.daz3d.com/doku.php/public/software/dazstudio/4/userguide/creating_content/modeling/tutorials/pbms/start
But keep getting geometry error.
(Noob and couldn't get pics to directly attach.)
I setup Genesis figure as base resolution, and then tried as poser export and daz export:
But when I try using the morph loader on base Genesis figure, it gives geometry error.
I know its something simple.
Thanks for any help to solve this problem.
591 x 726 - 42K
603 x 677 - 96K
549 x 592 - 93K
1308 x 563 - 167K
Be sure to hide the hair and any other props your figure is wearing, otherwise those are included in the export.
Removed all from scene except figure, and still the same.
Head scratcher since I followed document to the T and even tried a few suggestions as using use figure instead of groups.
Ok, so time to check your import/export settings in your modeling app- What are you using?
The most basic test would be to import and export without touching anything, but selecting and moving some polygons is basic enough to not break anything. (Unless you're using Sculptris, which can change the geometry as you work, I think by default.)
No I did morph in daz then exported to convert into morp dial, but think I am missing something.
I'll try exporting to hex or something first.
Thanks for help
