dropping particles, making em spin some randomness? (solved)
MistaraMistara Posts: 38,675
edited April 2021 in Carrara Discussion
Hi,  dropping realm coin.  is there a setting to make coins turn as they fall?  but not all exactly the same, some randomness
thanks
Post edited by Mistara on
  • DesertDudeDesertDude Posts: 1,239
    edited April 2021
    Hi Mystiarra,
    The bottom part of the Particle Emitter interface has a 'Unlink rotation from trajectory" checkbox - if you check it some controls for Orientation and Rotation Speed light up.
    (Picture should be bigger if you click on it)
    1464 x 490 - 79K
    Post edited by DesertDude on
    edited April 2021
    And here is a real quick set up as a test:
    Pretty much used the same settings as screen shot above.
    Orientation seems to change the initial orientation of the particle.
    Rotation speed is probably what you are after.
    I'm still a little confused about dialing in anything predicable, but to test I set the Particle Emitter to strictly create 1 particle per second. Then in the Assembly Room, with the Particle Emitter selected, under the General Tab I set the 'Particles displayed in 3d view' slider to 100% and set the Display dropdown to 'Mesh'. Then I could clearly see 1 particle per second and get an idea of what was happening dialing in different values in those controls.
    Not sure if that's any clearer. blush
    kewl.  thanks.  never realized what that checkbox was for.
  • mindsongmindsong Posts: 1,788
    that came out pretty cool!
    saved your howto to my cool C tricks folder as a PDF - tnx!
    best,
    --ms
    Mystiarra, mindsong,
    cool and thanks and glad it helped!
