I want this !!
PjotterPjotter Posts: 274
Not much here, because working on more important things, music.
I found something I would like to create In Carrara, but no idea how. Can someone point me in the right direction? I think it will be something like script + NLA.
An example is here https://www.youtube.com/watch?v=mZBGUQZV2dg It is amazing.
You just open a midi or karaoke file and the band plays. I have downloaded the demo.
Not sure if it is still supported or for sale, because cannot find a buy option. Contacted them. The site is at http://www.jasminemusic.com/visuoke.htm
  • PhilWPhilW Posts: 5,162
    Hmmm, the band just walk on and they then seem to be on an animation loop which is not related to the music, even the basic beat, at all. You could create a little animation sequence for each player in Carrara, save as an NLA clip and then loop that. Shouldn't be too difficult - and as you can change the timing of a loop, you could sync it better to the beat of the music!
  • WendyLuvsCatzWendyLuvsCatz Posts: 41,769
    I downloaded it for a look, cute but could get a bit old after a while
    I think one COULD indeed do something like it in carrara with PyCarrara and midi using NLA clips
  • PjotterPjotter Posts: 274
    I thought it would be something like that.
    Played several midi and karaoke pop files and some are pretty good. So far not found a buying option.
