UNDERSUIT
joshuabouillion87joshuabouillion87 Posts: 99
Is it possible to fit this obj. to the genesis 2 model. Basically taking the obj. and making it take the shape of the G2 model. For ex., if someone was creating a pair of pants for a model. Lets say a female model. Her pants would be tight fitting, conforming to her curves. Here is the obj. file that i want to fit on the G2 model. http://i773.photobucket.com/albums/yy13/joshuabouillion/conform_zps823bc6f1.png
    First of all, you can post images directly to the forum here, by using the 'Browse' button just above where you Submit your Post.
    Do you want to use this OBJ file as a bodysuit for G2F? Clothing needs to be conforming, that means that it is able to move along with the figure when it is posed. To do this, the clothing needs to be rigged in the same way as the figure it is intended for.
    Can you explain a bit more what you are trying to do, and where this OBJ file cam from?
  • TotteTotte Posts: 15,319
    The simplest way for an undersuit is to create skin with that texture and apply that skin to the figure, then add other clothing parts on top of that. There are several items in the store that use that approach.
  • joshuabouillion87joshuabouillion87 Posts: 99
    Not sure if i can explain it any better. I want the bodysuit for both male and female G2 models. If you look at Totte's post, i think that explains it a little better. Thought maybe I could take the OBJ file and make it fit the G2 model using hexagon. Looking at the undersuit the chest area looks a little flat. Even though you can see that the G2 model, and undersuit are pretty much scaled to the same height. I would like for the legs, chest, and arms of the undersuit to have a more muscular shape. Just like the G2 model. And the OBJ file was given to me from someone on the 405TH.COM. Its pretty much the Halo 4 undersuit.
    1366 x 768 - 421K
    Sounds like a quicker approach. Do you know of any good tutorials of going about doing this method. Also, what are those items in the store? That way i can check them out.
    I'm having internet blackout at the moment ( on 3G phone) so I can't list them. Wi as soon as things are back to normal.
