geoshell bodysuit? autumn soldier suit
MistaraMistara Posts: 38,675
i'm totally loving the look of this.
https://www.daz3d.com/autumn-soldier-for-genesis-8-female-s
its kinda like a deadpool for g8f.
it says geoshell body suit?  geoshells only work in ds?
i'm not worried about the 2nd skin looking suite,
i'll buy it if it has the wonderwoman part as conforming geometry.
is it possible to export a geoshell suit and saveas geometry and conforming?
10
Thanks!
  •  The only geoshell in this set is for the bodyglove. The rest is modeled.
  • McGyverMcGyver Posts: 7,102
    edited April 2021
    Autumn Soldier?... Sounds like DC trying to rip off a bit of Marvel madness... "The Pigeon and the Autumn Soldier"... "Coming this fall to HBO ++ Plus Extra"
    Post edited by McGyver on
    the name made me laugh, thinking spoof of winter soldier.  summer soldier wears a mankini.  tee hee
    thanks.  sounds good. smiley
  • ArkadySkiesArkadySkies Posts: 206
    10
    Thanks!
    I just checked, and I was able to export to export a geoshell as an obj and import it into Blender with zero problems. So yeah, you can import the .obj back into Daz as conforming clothing with the usual settings, but you probably don't need to and can just export it with your figure as normal, unless you want to remove the extra geometry. (Actually, no idea whether the bridges accept geo-shells, but standard .obj export works fine, so it probably does, but if doesn't, go ahead and export the obj and reimport it then make it a conforming item).
    Geoshells are still basically just regular 3D geometry. I think it's basically just the equivalent of a duplicated shrinkwrapped mesh over an original mesh.
    thanks.  is in my cart smiley
