GenX2 problem G->G2
Viper016Viper016 Posts: 159
I want to export http://www.daz3d.com/ideal-beauty-shapes-feet-for-genesis
from Genesis
to Genesis 2
How would I accomplish that bubs?
Are there any other feet shapes/morphs for Genesis 2?
  • LeanaLeana Posts: 13,508
    In order to transfer morphs from Genesis to Genesis 2 you will need Dimension3D's GenX2 program with the Genesis 2 add-on.
    GenX2: http://www.daz3d.com/genesis-generation-x2
    GenX2 add-on for Genesis2: http://www.daz3d.com/genx2-addon-for-genesis-2
  • Viper016Viper016 Posts: 159
    but i do Dx
  • SuperdogSuperdog Posts: 765
    Can someone please answer this question if they know how to transfer G1 to G2 morphs using GenX? I have all the GenX stuff - I just want to know how to transfer G1 morphs to G2. I've searched the entire internet, including YouTube, and can't find any tutorials for this process. The GenX & G2 Add-on manuals only explain the M4/V4 to G1/G2 process.
    Okay
    Load Gen X
    Load Genesis in Main Screen. Apply Character Morphs you want to transfer
    Select Source Figure Genesis.
    Create Single Morph
    Shape: Genesis
    Target (Applicable Gen 2 figure)
    Select Genesis Figure in main port
    Select all sections on the left (I highlight) them all
    Choose under Mode selection "Get values from figure in scene"
    Transfer
  • BeeMKayBeeMKay Posts: 7,019
    edited December 2014
    EDIT: Deleted, already explained by serenity. :-)
    Post edited by BeeMKay on
  • thd777thd777 Posts: 946
    What SereneNight said above works or even easier:
    Just set source to Genesis (no need to load anything), set target to G2M or G2F and the rest according to the screenshot. Then just select the morphs you want from the list and hit transfer. Done. In the example I transferred the "Troll Giant" head morph.
    Ciao
    TD
    1914 x 1035 - 126K
  • GeorgehazeGeorgehaze Posts: 200
    Okay
    Load Gen X
    Create Single Morph
    Shape: Genesis
    Transfer
    It's the "Load Gen X" part that has me stumped.
    With every other utility, this has been one of the 'panes' but I can't find it; am I looking in the wrong place?
  • Chris CoxChris Cox Posts: 57
    Go to
    Help>About Installed Plugin
    and make sure it registered, installed or something like that. If not you need to do that (sorry can't recall how exactly that is done)
    After that it should be available on the Windows>Panes (Tabs)
    Okay
    Load Gen X
    Create Single Morph
    Shape: Genesis
    Transfer
    Right click on the pane area around DAZ Studio and use the ADD Pane tab. Gen X if installed correctly will show as a plugin option as shown in this screenie.
    SereneNight
    1920 x 1080 - 351K
    Yes, I got it now. It wasn't there before so I just re-installed it.
    thanks though
