RHS Sweet shop in DS (SOLVED)
IkyotoIkyoto Posts: 1,159
Manually dl'd both version and installed. DIM - same result. Why won't things render when they show correctly in the working view?
565 x 800 - 297K
Post edited by Ikyoto on
  • Richard HaseltineRichard Haseltine Posts: 112,009
    It's the reflection maps - if you remove them or turn down the reflection strength it will look better (removing the maps and not adjusting the strength will make DS use real reflections, which can be slow).
  • IkyotoIkyoto Posts: 1,159
    edited November 2014
    I'll play with the settings as soon as the part 1 of "way too many" renders for composition is done. Thanks mate.
    PS - the rug obj is missing.
    The rug is part of the required product: Redhouse Christmas Carol Exp 1.
    The reflection settings were the issue!
