Daz Install Manager > Bryce & Pro
MatCreator
Does the daz installer install Bryce? I notice the actual Bryce installer does NOT get listed by the DIM. Of course I can install manually, but just wanted to double check to make sure. The DIM set up the paths of all the other Daz programs, I just want to make sure when installed, the other programs are "aware" that Bryce is there so they all play nice together.
Post edited by Chohole on
moving to the Bryce forum
We (as in We, the Brycers) do recommend a manual install, using the .exe file.
Thanks =)
As far as Bryce is concerned, DIM is dim
~ Yes , a manual install _ and read Horo's pdf ( if he will put up links )
_ thanx
https://horo.ch/docs/mine/pdf/BryceContent_v4.pdf
