Help with Object Files
KeiththegamergeekKeiththegamergeek Posts: 44
I have this spaceship model but it's all obj files and JPG textures. How do I install it so I can use it in DAZ? I've had similar models but can never get them to show up in any of my libraries.
    Under 'Other Import Formats' in the Content Library pane, right click, and select 'Add a Base Directory'. browse to the location where your OBJs are stored, and they should show up in content.
    You will need to create an icon for yourself, and load the textures probably
  • TotteTotte Posts: 15,323
    You can also import the obj using "File->Import" and if you have a .mtl file textures might be applied otherwise you need to apply them yourself. Then you can so File->Save As->Support Asset->Figure/Prop Asset.
  • KeiththegamergeekKeiththegamergeek Posts: 44
    I took your suggestions and was able to do both quite easily. :) Thanks!!
