Have New Issue another Character morph took over G8M folder
Have New Issue another Character morph took over G8M folder I tried to load G8M basic and get this new muscle bound morph character defromed to a point too.
Last New models I installed Manually was Yeti and Underbelly Thug, so not sure which one is causing it and I installed James for Christian 8, and also Hell Ambassador HD for Genesis 8 Male..
I tried to un-install Underbelly, but that did no good, so I re-installed him back in.
and I took a look at Hell Ambassador HD for Genesis 8 Male and that one body does not match up.
So not sure which one it maybe, and in the last two days I installed a lot of bundles and new characters and props and stuff.
I am hoping one of you may reconize the body shape and know which one it maybe and I will see if I have it in my folders and then go to Daz and see and uninstall it to fix the issue.
Mod Edit :_ Image removed due to nudity
1920 x 1080 - 498K
Post edited by commando991_70eecfd4fc on
  • Lee MoonLee Moon Posts: 941
    Hi there, commando991.
    Try looking in your Currently Used section of the Parameters Pane (lower right quadrant of your attached screenshot.)  See what morphs are non-zero.  That may tell you which characters are getting loaded.
    I don't recognize the character, but someone may come along and identify him.
    Also, one of the moderators will likely require you to change the preview mode to smooth shaded instead of texture shaded in your screenshot.  You might want to go ahead and replace the current attachment with the smooth shaded version to comply with forum rules. :)
    Hope this helps!
    Lee
  • edited April 2021
    Hope this helps!
    Lee
    Tried that can't really tell to many Morphs !!
    I got over 1000 !!!
    And Texture shade is not as realistic as Nvidia pre-renender !!!
    So again they need to Grow up and get a pair like real men and women, its a Fake 3D model !!
    It's not real, when you people going to under stand that, a real nude photo or image will have merte to Pornography not a 3D model render, and who would get off on a 3D model image anyway, that just shows immaturity !!
    And the Models has "NO" gentitals at all !!!! I doubt their case will hold in court, if it ever went to court !!!
    And if a kid or teenager can't tell the difference of a 3D model and a real person image they have a problem and major, major issues, just like these Daz,inc Foram board moderators do !!!
  • edited April 2021
    Here's a Update image of the Genesis 8 Male basic character and its not the normal model, it loads like this now, I uninstalled Majestic Anubis with dForce Hair for Genesis 8 Male, The Abomination HD for Genesis 8 Male, Underbelly Bundle.
    So I been back tracking what I installed for Genesis 8 male models, because it only effecting that area.
    But still no luck to whats doing it, so far!!
    I zeroed the figure out to show the diffrence.
    Oh' ya" by the way I Zeroed out the Figure and tried to save back as Genesis 8 Male basic model and it saved, just still kept on loading the other figure.
    1920 x 1080 - 677K
    1920 x 1080 - 681K
    Post edited by Chohole on
  • edited April 2021
    I just tried to apply Dan Morph figure to a Zeroed out Genesis 8 Male basic figure and this it what happened and its the Model that looks like Dean Winchester from Supernatural TV show.
    But it does not look like him now !!
    1920 x 1080 - 605K
  • wyvern13wyvern13 Posts: 13
    edited April 2021
    In a new scene, load up the base G8M. On your "Shaping" tab click on the thin black line at the top labeled "Currently Used." For the base character with nothing added all you should see is 3 Eyelash morphs set to 100. Any other morphs in that pane are morphs being loaded by default that should not be. This information will help you track down the character that is messing things up without trying to uninstall random characters.
    Anything extra on that tab is your problem character.
    Dan should load with these morphs:
    1000 x 839 - 385K
    Post edited by wyvern13 on
  • edited April 2021
    Thanks alot :), trying it now to find them and uninstall them, what I found was two of them.
    christian 8 <----- This one was the culprit !!
    James <<<<< this one too, Oh' well I was hoping to use that one since he was a clone of X-Men wolverine.
    even though it did not look anything like him or the actor, but it had bone claws and Steel claws.
    edited April 2021
    You said in your first post you just installed "James for Christian 8." That's clearly the problem character. (Since it's based on Christian 8, it's loading some of his morphs, just like Dan loads Mike 8's morphs.) Christian 8 is fine to re-install.
    I've never used that character, but you should file a ticket so it gets fixed if it's loading by default. There is a way to make it so you can use him in the meantime (it just involves replacing a 1 with a 0.) The method is described in this thread.
  • Richard HaseltineRichard Haseltine Posts: 112,003
    As far as I know those have been updated - redownload (in Daz central/Daz Install Manager or from your product library) and reinstall.
    Sorry for the Late reply back, but Thanks alot for your help and informaiton about the James model.
    Yes, your are "RIGHT" itwas James model all along masking the others.
    I just took out one of it model loaders and it fixed it.
    the Diosplay Character section one works fine.
