Run AND Jump aniblocks
Correct me if I'm wrong but currently there are no aniblocks for jumping.
Example use case: One of the things I use DAZ Studio for is concept visualizing/animatics things that would happen in first/third person games and something that frequently happens in those types of games is jumping from platform to platform.
If there existed some aniblocks to do this, I would buy them in a heartbeat.
  • DiasporaDiaspora Posts: 555
    edited April 2021
    Most people expect commercially available aniblocks to be made with motion capture so it's likely to be difficult to produce this cause you would need a motion capture rig that can capture a range of motion across quite a long stretch of space.
    Post edited by Diaspora on
  • Well, the one thing I could do is recreate the Mixamo version by manually posing the appropriate bones.  If I do it in 12 frames per second, the work will be more efficient.
    Just my own opinion, as long as you make sure the feet aren't glitching through the ground, that sounds like it would yield a passable result.
