DAZ Studio Pro 4.7 Beta Install Problem
csteell_c2893e4ab6csteell_c2893e4ab6 Posts: 542
Everytime I go to install DAZ Studio Pro 4.7 Beta via Daz Install Manager my install manager crashes. Any suggestions? Cheers
  • fixmypcmikefixmypcmike Posts: 19,742
    What Operating System? On Windows 7 the log files will be in C:\Users\[username]\AppData\Roaming\DAZ 3D\InstallManager -- they are called log.txt and hlog.txt -- after the crash what are the last 10 lines of each log?
  • csteell_c2893e4ab6csteell_c2893e4ab6 Posts: 542
    I do not know as I cannot re open Daz Installer! Cheers
    Is this what you mean? Cheers
    +++++++++++++++ Install Manager 1.1.0.28 starting +++++++++++++++++
    OS bits: 64
    Platform bits: 32
    Qt Version: 4.8.6
    Locale: en_US
    Running on Windows 7, Build 7601, Service Pack 1
    Physical Memory:
    Total: 3.9 GB (4294967295)
    Avail: 3.9 GB (4294967295)
    Virtual Memory:
    Total: 3.9 GB (4294836224)
    Avail: 3.8 GB (4157521920)
    Current Memory Usage: 19%
    Current DateTime:
    Loc: Sun 16. Nov 15:37:59 2014
    UTC: Sun 16. Nov 04:37:59 2014
    Application Data:
    Location = C:/Users/Charles/AppData/Roaming/DAZ 3D/InstallManager
    Disk Total: 1.8 TB (2000396742656)
    Disk Avail: 1.0 TB (1117948633088)
    Reading dzInstall.ini
    Current Account: Account
    Current Download Path:
    Location = C:/Program Files (x86)/DAZ 3D
    Current Content Install Path:
    Location = C:/Users/Public/Documents/My DAZ 3D Library
    Current 64-bit Software Install Path:
    Location = G:/Poser Pro 2014
    Disk Total: 930.8 GB (999500541952)
    Disk Avail: 6.9 MB (7335936)
    Current 32-bit Software Install Path:
    Location = C:/Program Files (x86)/Smith Micro/Poser Pro 2014
    Connected to CMS: PostgreSQL 9.3.4, compiled by Visual C++ build 1600, 64-bit
    --------------- Install Manager exited ------------------
    Some of those paths don't look right:
    1) Current Download Path:
    That could be causing problems, as Program Files/Program Files (x86) are protected folders.
    2) Current 64-bit Software Install Path:
    Normally these paths default to C:/Program Files and C:/Program Files (x86) -- did you intend for DAZ Studio to get installed inside the Poser Pro application folder?
    Are you currently unable to launch DAZ Install Manager?
    This is the Hlog.Cheers
    +++++++++++++++ Install Manager Helper 1.1.0.28 starting +++++++++++++++++
    OS bits: 64
    Platform bits: 32
    Qt Version: 4.8.6
    Locale: en_US
    Physical Memory:
    Virtual Memory:
    Avail: 3.8 GB (4163387392)
    Current Memory Usage: 15%
    Current DateTime:
    Loc: Sat 15. Nov 16:13:53 2014
    UTC: Sat 15. Nov 05:13:53 2014
    Application Data:
    Disk Avail: 1.0 TB (1119050694656)
    Helper application data path: C:/Users/Charles/AppData/Roaming/DAZ 3D/InstallManager
    Product successfully installed : Scene Builder for DAZ Studio
    I still cannot open DAZ Install Manager! Cheers
    Can you uninstall it and redownload it from your Product Library ( https://www.daz3d.com/downloader/customer/files#prod_14810 )?
    Should I uninstall DAZ Install Manager and re install it? If so where should I point the application? Cheers
    The default location is C:\Program Files (x86)\DAZ 3D\DAZ3DIM1
    OK I have un installed DIM and put it in (C:)Program Files (86) DAZ3DIMI. Now this is where my problem starts with downloading DAZ 4.7 Beta as to where to put it. Perhaps I have my DIM set up wrong? Can you assist? Cheers
    OK, click the gear (Settings) icon in the upper right corner. On the Downloads tab it shows where you're downloading files to -- the default is C:/Users/Public/Documents/DAZ 3D/InstallManager/Downloads
    Then on the Installation tab, the defaults are:
    64-bit software: C:/Program Files
    32-bit software: C:/Program Files (x86)
    For installing content, the default is:
    Label Path
    Recommended... C:\Users\Public\Documents\My DAZ 3D Library
    If you need to put things in other locations, that's fine, but don't put anything other than the 2 software locations in Program Files.
    I re- installed and tried to download DAZ Studio 4.7 and DIM crashed again and it will not open! Everything is set to what you have recommended and it still crashes and will not open. I think I will give up! I have never had any problems before. Only this Beta installation. Many thanks for your help.Cheers
