SOLVED - Help! Renderer renders nothing
DiomedeDiomede Posts: 15,457
edited April 2021 in The Commons
The renderer was rendering.  Was able to edit scene, rotate camera, and render tests.
Now the renderer only renders blank canvases.  No error.  The last thing I did prior to the problem was create a plane primitive and place an image on it.
1894 x 1013 - 481K
Post edited by Diomede on
  • VenomisbeautyVenomisbeauty Posts: 139
    edited April 2021
    I think you should restore render settings to "Defaults", you see an icon on top of render settings menu
    1068 x 504 - 5M
    518 x 227 - 5M
    Post edited by Venomisbeauty on
    edited April 2021
    SOLVED!
    I am doing a daredevil balloon scene like The Great Leslie in the opening scene of The Great Race.  I had rotated the camera to point up at the balloon.  Unfortunately, I rotated below the ground plane with the render setting still set to draw the ground.  Fixed by unchecking draw ground in render settings.  blush
