Shader Material Property Swapping Script/Pane
gitika1
I would love a script product that works with and allows the swapping of individual selected shader surface properties.
- When opened, on one side of the interface it would show the surface materials/settings for the item currently selected.
- It would have a section/panel where I can select from currently installed shaders.
- After selecting the second shader/material, I would see a corresponding list of surface materials, as it would be if applied to the selected object.
- With both material/surface properties visible, I would then be able to select the properties I want to apply to the current object; and only those would be changed.
Why? I have some favorite PAs who properties for different types of shaders that I love; but sometimes another product may have a cute pattern, topcoat, and/or bump/normal map. I end up making a primitive and applying the the second shader to it. Then comparing the different properties. I then dig through folders and changing out particular properties, while endeavoring to keep Glossy/Scatter/Metallic etc properties that better suite my needs or fancy. A script interface would save me time, comparing two shaders, deciding which properties I want to keep from each, then noting the pieces parts locations, and swapping maps out.
