DS 4.14 req Logins ....
Can anyone explain why DS4.14 suddenly requires Logins (to DAZ Acct) after I've shutdown/restarted my machine?
Also, I run a dualboot sys, and DS requires logins if I've moved from one OS back to W7?
Basically, is there a way to stop this recent behaviour?
YB
  • Richard HaseltineRichard Haseltine Posts: 111,949
    Choose Work Offline, I can't recall how it appears on the start screen but there should be an option (if it isn't clear, please post a screen shot).
    Thanks Richard, I understand that part; but its giving ".. system changed, must logon to use content..." msg. It then locks out certain DS installed content ( I think mostly installed vis DAZ Connect)... very aggrivating to have to constantly go through log-ins like this."
     I'd like to know why DS is 'trolling' shutdowns and or VM activity.. Neither are changing system specific identifiers.. and what reason would DAZ have for that anyway (as the program is freely given away)...
     Perhaps I should submit a ticket?
  • Richard: also
     do you know a way to set 'sensitivity' values in Params to a default value beside the 1.0 so it becomes universal to the system?
     Seems you have a lot of insider knowledge in all things DS, you part of the 'team'?
    That means that DS thinks there has been a change and needs to reactivate the machine - but as far as I know that affects only encrypted daz Connect content, and unless you have a really old installation there isn't any of that.
    I'm not aware of a way to change the default sensitivity, sorry.
