Issues with Some G8F Outfits on G8.1F Figures
So I have been trying out the new G8.1F figures for a few days, and most of my G8F outfits work perfectly fine with 8.1, but I'm having some issues with two outfits: MR Nya bodysuit and the MR Shary bodysuit.  When I use either outfit on an 8.1 figure, the bodysuit applies to the limbs, but not the torso, which simply turns white.  Is there anything I can do to make the two outfits work on 8.1, or is it up to the original creator to update them for 8.1 first?  (I was under the impression that all G8 outfits should work with 8.1 figures, or was I mistaken?)  I'd appreciate any help.  Thanks.
PS: I have attached a screenshot of what happens when I use the Nya bodysuit on one of my G8.1F figures.
1669 x 970 - 591K
  • MimicMollyMimicMolly Posts: 2,376
    8.1 no longer has a "torso" material zone. It's now "head" and "body". What you can do is select the head and body part of the Geoshell and apply the Iray Uber Base shader on it. (Geoshell always loads in 3Delight for some reason.) Then load up a G8 and copypaste the "torso" materials to both the "head" and "body" zones. Delete G8 and re-save this new Geoshell preset (in Save As) Wearable Preset. That way you won't have to copypaste it a second time and it'll load.
  • sagyz127sagyz127 Posts: 0
    Thanks!  I will give it a try.  =)
