Copy and paste all Rotate Min-Max settigs in one time?
Hello to all.
There a way or a script to copy all Rotate Min-Max settigs from a model and past them to new one, all in one time?
Thanks.
  • Richard HaseltineRichard Haseltine Posts: 112,021
    If you put the Parameters pane in Edit mode you can set Max/Min values on all selected properties via the right-click menu>Set, however that works only if alla re to have the same values. Otherwise I think you'd need a script.
  • riomairiomai Posts: 44
    Thanks Richard... So I need a script.
