Victoria 8.1 renders gray
Hello!
When I render Victoria 8.1 out of the box she's colourless. Regardless of light.
Only way to get rid of this is to reset the texture and start over with basic Iray or select another set of textures.
What is wrong? What must I do?
I use DAZ 4.14
  • SquishySquishy Posts: 727
    exactly (really exactly) what steps are you taking to set up a scene, and can you show some images of what the output looks like please. screenshot of render settings would be OK too.
  • Richard HaseltineRichard Haseltine Posts: 111,831
    Are you using Daz Studio 4.15.x.x? Have you installed the updated Default Resources?
  • LeanaLeana Posts: 13,616
    Hera said:
    Hello!
    I use DAZ 4.14
    Victoria 8.1 uses the new PBR shader, which requires DS4.15.x
  • HeraHera Posts: 1,972
    edited April 2021
    Leana said:
    Hera said:
    Hello!
    I use DAZ 4.14
    So where does one find 4.15?  The download studio link is broken these days and so are my automatic updates...
    edited April 2021
    Hera said:
    Leana said:
    Hera said:
    Hello!
    I use DAZ 4.14
    Download a fresh copy through DIM/Daz Central and install it, with DS closed. You can also use the Public Build (beta) which will leave the geenral release alone - that has to be installed through DIM.
