How to fit V4 (victoria 4) hair into G8F (Genesis 8 Female)
Hello Friends,
I want to add a V4 hair (preferably the wet hair for V4) to my Genesis 8 Female. I used RSSY Hair Converter v4 to G8F tool, but they are not loading the files at all. I use the latest Version of DAZ Studio i.e. 4.15
So I am now looking for an alternate way to do so.
If anyone can help, please let me know.
With regards,
Souwrit Ray
  • onixonix Posts: 282
    As I noticed fitting hair is a pretty bad idea in general because it will deform it and make look wrong.
    So rather than fitting it just parent it to the head and just its size and position aproriately.
  • BlueSiriusBlueSirius Posts: 86
    edited April 2021
    Fitting older hair it also takes on a tonne of morphs being most everything applied to the figures body.
    As onix says what I do is I will import the hair without the figure selected, with the figure in start pose and no morphs. Move the hair over the figure and adjust x, y and z scale till it looks ok. Parent it to head, if this tries to fit it then parent it to a null and parent that to the head.
    Post edited by BlueSirius on
  • JakeEdwardJakeEdward Posts: 60
    Brilliant I forgot all about using nulls.  Nulls save A LOT of parenting issues etc
  • MasterstrokeMasterstroke Posts: 2,512
    Search for hair by Linday here at the store.
    Looks (wayyyy) better, it's dforce and it is made for G8F.
  • ThatOminThatOmin Posts: 43
    souwritray2009 said:
    Hello Friends,
    With regards,
    Souwrit Ray
    I usually just do it manually.
    I never convert or conform any of the hair not for the model it was made for, because I find it easier using my method.
    Especially, because sometimes, the morphs won't work if you conform or convert to a model it wasn't made for.
    So...
    - I load the G8 ( or whatever to be honest)  in the default position, then I load the hair of whatever generation I want to use.
    - I then fit it to the characters head, with scaling and moving it.
    - Then I parent the hair to the characters head.
    - You can also add "D-Force" to most V4 hairs to make them more "fluid".
