[Released] Props and Poses Converter from Genesis 2 Male to Genesis 8 Male [Commercial]
RiverSoft ArtRiverSoft Art Posts: 6,972
edited April 2021 in Daz PA Commercial Products
Easily use your Genesis 2 props, accessories, and poses with your Genesis 8 Male characters with the Props and Poses Converter from Genesis 2 Male to Genesis 8 Male!
It automatically converts almost your entire library of props, accessories, and poses. The Props and Poses Converter script provides batch execution for automatically converting your Genesis 2 Male props, accessories, and poses to Genesis 8 Male props, accessories, and poses in your library. Easily select the Genesis 2 Male props and poses in your library, select an output directory, and execute the script. Even better, icons and categories are copied from your Genesis 2 Male prop or pose to the new Genesis 8 prop or pose.
Your new Genesis 8 Male props, accessories, and poses are completely Smart Content-aware and will show up when you select a Genesis 8 Male. Plus, all the materials shown in Smart Content for your Genesis 2 Male prop or accessory will show for your converted Genesis 8 prop or accessory.
Items without metadata can be converted but will not show up in Smart Content. They may also need to be converted using a Force Convert Item(s) button. Zero Poses are not converted.
  • Convert Genesis 2 Male props and accessories for use by Genesis 8 Male characters*
  • Convert Genesis 2 Male Posed Props (e.g., Hand Gripping a Sword) to Genesis 8 Male Posed Props
  • Convert Genesis 2 Male Poses to Genesis 8 Male Poses
  • Convert Genesis 2 Male Hierarchical Poses to Genesis 8 Male Hierarchical Poses**
  • Convert Swords, Bows, Glasses, Jewelry, etc.
  • Convert Accessories: Hats, Belts, Glasses, Jewelry, etc.
  • Copies icons from Genesis 2 Male Presets to Genesis 8 Male Presets for a professional look
  • Converted Items are Smart Content enabled! All materials shown in Smart Content for your Genesis 2 Male props and accessories will show for your converted Genesis 8 Male props and accessories.
  • Automatically convert almost your entire library of props, accessories, and poses with one operation!
*The Props and Poses Converter script does not work with multi-part props (e.g., two daggers are loaded from the same preset) or with props/accessories with Genesis 2 Bone rigging.
**Hierarchical Poses require extra steps due to the props needing to be loaded. Also, due to a limitation in the Daz Studio script interface, some Hierarchical Pose Presets will need a manual step to be converted correctly.
  • Props and Poses Converter from Genesis 2 Male to Genesis 8 Male:
    • Props and Poses Converter Script (.DSE)
    • User Manual Script (.DSA)
1000 x 1300 - 427K
1000 x 1300 - 387K
1300 x 1536 - 513K
1641 x 1000 - 408K
1000 x 1300 - 369K
1000 x 1300 - 387K
1320 x 1000 - 287K
Post edited by RiverSoft Art on
