Help with a morph please
I've done several morphs and they worked.  But this one is giving me fits.  It's for a prop I modeled in Blender.  Instead of doing what it's supposed to do it just scales the whole thing.  I zeroed out the position for it in Blender.  Any ideas?
  • Richard HaseltineRichard Haseltine Posts: 111,842
    That sounds like a mis-matched preset in the morph importer and the OBJ importer options dialogue.
  • How do I fix that?
  • Oh derp never mind.
  • I tried all the different size imports with no luck  :(
    What preset is the OBJ import dialogue using, and does thatb line up with the prop you have in DS?
  • I tried them all.  It seems to load fine but morphing just changes size.  Dunno.
    Well, is the OBJ export using one or is it set to Custom? What happens if you export the morph OBJ as an object, does it come in at the same size as an import of the original prop's OBJ?
  • It just imported as the same size of the object.
    OK, so do the settings in the OBJ import dialogue match the settings in the morph loader dialogue?
  • backgroundbackground Posts: 941
    edited April 2021
    Is your original object at 100% scale before you load the morph? Ideally it should be , but if it isn't you can get around the problem by importing the morph with morphloader pro, and turning on 'reverse deformation'.
    Post edited by background on
