How do I export a DAZ prop to Poser?
I know how to export a figure to Poser (without hair and cloth through)
But how do I export a DAZ prop to Poser?
Do I must convert the prop to figure?
If it is, then how do I convert a prop to figure in DAZ?
Older DAZ 3D props are in Poser format already (PP2) so there should be no problem there.
If the props are in .DUF format, then you should be able to use the DSON importer for Poser http://www.daz3d.com/dson-importer-for-poser
What version of Poser are you using, and what format is the Prop in?
I'm using Poser Pro 2014, and my prop is .DUF format.
I already have installed the DSON importer for Poser, but seems I can only load Genesis figure, the DUF format files still not show in my Poser's library.
Since you have the DSON importer installed, I suggest you go to Dimension3D's website.
http://d3d.sesseler.de/index.php?software=poserpython
Pick up his DSON loader script. Place the script in the same Python folder where his other scripts are. Pro 2014 comes with a number of Ralf's scripts included. Just unzip the loader files to the same folder.
Simple props are best. Large and very complex meshes can have issues. You may also need to manually apply and tweak material settings in the Poser material room.
or just file->export-> choose wavefront object type, and then poser scale in the box that pops up..
