Models changing positions when removed from groups
Hi all
Daz has suddenly started doing this thing where if an object is taken out of a group, it will change its position within the scene. I'm sure I simply changed a setting somewhere along the way and don't know what it was, but it never used to do this until a day ago.
Can anyone advise me on how to fix this please?
Thanks!
  • margravemargrave Posts: 1,822
    It has to do with converting local coordinates to global coordinates when the group has a non-zero origin. One way to "fix it" is to ensure your groups are always at 0,0,0.
    I'm very interested if there's an option to keep offset when unparenting too.
  • Richard HaseltineRichard Haseltine Posts: 111,290
    Make sure that Parent In Place is on, either in the change parent dialogue if you are using that or in the Scene pane option menu (the lined/hamburger button in the top coirner, or right-click the tab) if you are using drag-and-drop.
  • OVDOVD Posts: 262
    I usually just group by mass-selecting objects in the Scene pane and then the group button. It always worked before, so I'm not sure what's changed.
  • OVDOVD Posts: 262
    That was it! Thanks Richard. I must have deselected it there accidentally.
