I'm having trouble with teeth whiteness
halfmast88
I don't know what to do to teeth to keep them from being overly bright and reflective. Most of my renders are not toothpaste advertisements so its sort of a problem. Does any one have any pointers for making them look more realistic? -Thanks
Go into Surface tab after you select the teeth with the surface tool (looks like three sheets of paper)
Change the diffuse to a gray, go a medium to a light color. In your specular, try a bit more blue- so a grayish blue. Ambient you can play around with, it depends on your light set as to whether you want to tweak that much. The main thing is the diffuse.
In my art studio thread I have shown darkened teeth several times. I Googled it and managed to find one that had the Diffuse color listed and you can see the example:
http://www.daz3d.com/forums/discussion/38051/P1080/#630549
