d-force timeline keys
Can someone point me to a resource that would allow me to modify d-force parameters on the timeline?  For example, friction change from one time to another.  Can you do that?
  • Richard HaseltineRichard Haseltine Posts: 111,268
    I don't think so, not directly - theya re surface proeprties and those are not currently aniamtable. However, properties can be linked to objectb properties via ERC, and that can be set up via a Post Load script as in http://docs.daz3d.com/doku.php/public/software/dazstudio/4/referenceguide/scripting/api_reference/samples/start#post-load_data_items so I think it would be possible to implement with some coding (assuming the variable values were passed to the simulation engine).
  • SquishySquishy Posts: 725
    Better keyframe support for this kind of thing would be great.
  • RobinsonRobinson Posts: 751
    OK thanks, I'll employ some "tricks" to do it (moving across a material change, effectively).
  • ThatOminThatOmin Posts: 43
    edited April 2021
    Keyframing definately needs to be changed in this program. Seems this GLARING and obvious problem is overlooked and ignored despite having 100's of threads about it.
    I mean, resetting and deleting keys should have a priority.
    How are you  going to have some CLOTH SIMILUATION that is highly dependant on it and I have to spend hours trying to remove keyframes, sometimes ruining my whole scene?
    Just Google "Can't Reset Keyframes" it's been next to a decade or more and this still hasn't been changed.
    dForce should be marketed as: Better Get It Right The First Time Because If Not...
    In fact, I should start linking the 100s of threads about this because it's pretty ridiculous at this point.
    Post edited by ThatOmin on
    Removing keyframes is simple - but it depends on the selection you have.
