Alternative Fonts / Font Sizes?
Hi,
In the GUI scripts that I'm working on, I'm getting a little tired of the small size & shape of the standard font that appears in
all of the DAZ scripting widgets.  Has anyone succeeded in outputting any other kinds / sizes of fonts?  If anyone has, I'd be
interested to see the code fragments.   Thanks.
  • PraxisPraxis Posts: 292
    The only DzWidget I know of that supports font changes is DzTextEdit, which provides properties such as .pointSize, .textColor, .bold, .font, .family, etc.
  • jag11jag11 Posts: 885
    The only successful way is using Qt Designer, set QDialog styleSheet property and all child controls adopt parent settings.
    Save the dialog as a .UI file and load it from a script.
    1027 x 559 - 78K
    Hah!  That works.  Thank you! smiley
  • Richard HaseltineRichard Haseltine Posts: 111,677
    Do bear in mind that Daz is working on updating the Qt version used, soemthing we have been told is necessary for the application to suppot scaling. Using tricks to get a degree of scaling now may cause issues if application-wide scaling becomes available.
