Adrianna V6 - Head morph problem Poser Pro 2012
sagorusagoru Posts: 32
Hi all,
I have a problem with Adrianna V6 in Poser Pro 2012 because I can't apply the head morph. After injecting the head morph on v6 nothing happened, if I check on parameter dials, below Head/People/Real world I found Adrianna but even if I put the value to 1 it doesn't works. All is ok on DazStudio!
Thank you in advance for any help you can provide and sorry for my bad english!
K.
  • Richard HaseltineRichard Haseltine Posts: 111,363
    Are you sure you installed the Adrianna files to the same location as the rest of your Genesis 2 Female characters and the base figure?
  • sagorusagoru Posts: 32
    Thank you for your answer, and yes, but the problem is that v6 takes the body morph or the materials, but no the head morph...
