Model renders in purple.
Hi folks, I've recently got back into Daz Studio after being away for many years.
I picked up the FG Decor and Lighting pack and I've run into an issue when rendering that I haven't been able to find the answer to.
When I render the decor items they all display properly, however, the lighting items that I have tried so far render in purple.
I assume it's something I need to change so if anyone could point me in the right direction I would appreciate it.
Thanks.
1278 x 702 - 416K
https://www.daz3d.com/forums/discussion/482656/some-of-my-textures-are-bright-pink
You're not the only one.
Did you check the Surfaces tab to make sure the texture maps are there? In other 3D programs, bright purple is usually a warning about missing textures.
Checked the surfaces tab and there are texture maps for the lights.
I looked at the post you linked, and I see I'm not the only one experiencing this.
I'll continue to play with it and if I have no luck I'll put another ticket to go along with the one I have in for the Postgre error
Thanks.
