Daz3D studio - All pose changes to a single morph?
Is there a way to make a morph after changing the figure pose?
For example, I re-pose the figure (move arms, legs etc) and then I want to save all of this changes as a single morph/shape (not as a pose)
I tried to export the figure as .obj and then do the morph loader pro but it fails. It says geometry is different or something. And that's the end of my ideas how to do this
    Before exporting to OBJ, did you set the figure to base resolution? Without it, you can't import the OBJ back as a morph to that figure.
  • LeanaLeana Posts: 13,641
    If using G8 you need to remove the eyelashes too.
    I would suggest creating a "master dial" to apply the changes rather than exporting as obj and reimporting as a new morph.
    The reason is that with a master dial you keep the link to all corrective morphs which were used when the figure was posed, while you would lose them with a new morph. If you plan to use that morph at something else than 100% or to mix it with other changes you'll get better results with a dial.
