Render same, but more y axis size
I have rendered an Image 16:9, 3840:2160px
I would like to render the exact same scene just having more of the Sky and above objects in the Image. So simply more size on the y axis, but no other change.
How can I achive this?
When I change aspect ratio or Pixelsize the camera just zooms in.
As I want it exactly the same I also don't want to move the camera.
  • AnimAnim Posts: 241
    edited March 2021
    Maybe I am missunderstanding your question but anyway I give it a try.
    With disabled "Constrain Proportions..." you can set the height and width of the render independently. Changing the heigt might be what you refer to as Y axis.
    671 x 409 - 53K
    Post edited by Anim on
  • Muffin64Muffin64 Posts: 32
    I already tried this. The problem is, dimensions change but my camera is then closer to the objects as well. I want the camera staying in the very same position.
  • Richard HaseltineRichard Haseltine Posts: 111,306
    Try editing the frame size of the camera you are using to match,
  • margravemargrave Posts: 1,822
    Even if you change the dimensions, the position does not change in Daz units. However, the wider frame may distort the image so it looks farther away. In that case, adjust the camera's focal length.
