Is DAZ Studio really rendering when I'm doing something else?
SotoSoto Posts: 1,451
...Because I`m starting to think it´s not.
I used to left it rendering and the render would be done while I was doing something else. but since I switched to a Mac, it feels like the render is on pause while I'm doing something else and resume activitiy when I go take a look.
Is this some kind of RAM optimization maybe? Or just my imagination?
  • nightwolf1982nightwolf1982 Posts: 1,319
    Might be, might not be. I don't know how it works on a Mac, but in Windows, you can adjust the CPU priority for different processes. Higher priority processes get more of the CPU's cycles.
  • mawkroymawkroy Posts: 21
    You may want to check Activity Monitor and make sure DAZ isn't set to utilize App Nap. This feature suspends certain programs when you switch to another program. I believe you can disable App Nap by right clicking on the DAZ app icon inside /Applications, selecting Info and unchecking the App Nap tick box.
  • Cris PalominoCris Palomino Posts: 12,932
    Having always worked on a Mac and having done tons of renders with DS when I am working in up to 5 other programs at the same time, I can assure you it continues to render. The closer to the end it get, the finer the bits, the longer it takes. My renders invariably take 3-8 min to get 75% of the way there and then, depending on the complexity of the scene, number and types of light, alphas, etc. can take up to some hours for the rest.
  • SotoSoto Posts: 1,451
    Thanks! That might be the cause... I had to do the opposite and check "Disable App Nap" but might be because I'm on Yosemite.
    Thanks for the tip! Will see if I notice the difference. :D
    Yep, I'm also on Yosemite.
    Greetings,
    Thank you; I hadn't realized I had to explicitly 'prevent app nap' for DAZ Studio! That would have made me REALLY mad if it paused my render when other stuff was going on...
    Yeah, it's a new OS X feature that really sucks for the software developers, but is probably good for most users, and can significantly lower the energy usage of a computer. (I put out a free program that lets folks snipe on eBay items. You can imagine just how horrible App Nap is for my program. I spent a lot of time putting together a plugin for my application that disables App Nap for it.)
    -- Morgan
